  1. To enter User EXEC mode, log on to the switch.
  2. Verify the interface configuration on the VLAN:
    For IPv4, enter: show interfaces vlan ip
    For IPv6, enter: show ipv6 interface vlan
Verify the IPv4 interface configuration on the VLAN:
Switch:1(config-if)# show interfaces vlan ip
                                                   Vlan Ip
VLAN VRF    IP            NET              ADMIN     OPER   ADVERTISE DIRECTED  RPC     RPCMODE     RMON
ID   NAME   ADDRESS       MASK             STATUS    STATUS WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9     255.255.255.0    enable     up    disable   disable   disable exist-only  disable
1102 Globa~ 198.51.100.1  255.255.255.0    enable     up    disable   disable   disable exist-only  disable
1133 iir3   192.0.2.10    255.255.255.0    enable     up    disable   disable   disable exist-only  disable
1500 spboip 192.0.2.11    255.255.255.0    enable     up    disable   disable   disable exist-only  disable
1590 spboip 198.51.100.2  255.255.255.0    enable     up    disable   disable   disable exist-only  disable
4057 Globa~ 192.0.2.12    255.255.255.0    enable     up    disable   disable   disable exist-only  disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF           BCASTADDR REASM      DVR     DVR
ID   NAME          FORMAT    MAXSIZE    STATE   GW-IPv4
1050 GlobalRouter  ones      1500       disable  -
1102 GlobalRouter  ones      1500       disable  -
1133 iir3          ones      1500       disable  -
1500 spboip        ones      1500       disable  -
1590 spboip        ones      1500       disable  -
4057 GlobalRouter  ones      1500       disable  -
Verify the IPv6 configuration on the port:
Switch:1(config-if)# show ipv6 interface vlan
                                             Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX        ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
3170   1122 2c:f4:c5:dc:b4:89 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3174   1126 2c:f4:c5:dc:b4:8b enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3185   1137 2c:f4:c5:dc:b4:90 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:1                      V-1122       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489          V-1122       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1126       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b          V-1126       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1137       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490          V-1137       UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
